1997 Honda Civic
160,000 MILES • 4 CYL • FWD • AUTOMATIC
ELCACHANILLA
quiero saber como recargo mi aire acondicionado despues de haber cambiado mi ac condenser porque ni el compresor prende porque el sistema esta vacio
Aug 12, 2008 at 3:58 PM
  • 31,937 POSTS
Hi there,
You will have to get the system vacuumed down, and make sure that it holds the vacuum as this is the test for a leaking system. When this has been done the refrigerant can be added to the system, it is a good idea to use the correct gauge set so you don't under or over charge the system.
Mark (mhpautos)
Aug 12, 2008 at 5:18 PM
