1997 Honda Civic
RBY62
  • 1997 HONDA CIVIC
  • 4 CYL
  • 170,000 MILES
The transmission is slipping on my 97 honda civic and someone told it couldn't be serviced, Is that true? I thought I could change the filter and fluid?
Wednesday, July 16th, 2008 AT 12:15 PM
KHLOW2008
  • 41,814 POSTS
Hi rby62,
The filter cannot be replaced, it is a non maintenance item located deep inside the trans assy.
If the slipping is due to low fluid or improper throttle cable adjustment, there is still hope, otherwise it needs a rebuilt.
If it is a CVT trans, incorrect spec of fluid used will cause slippage.
Wednesday, July 16th, 2008 AT 12:35 PM
