1996 Honda Civic Transmission Trouble Code
DROWSER
  • 1996 HONDA CIVIC
  • 4 CYL
  • 130,000 MILES
I'm getting a trouble code P1768 and the only information I can find is that's it's the automatic transaxle. Does anyone know the specific component that the code refers to. Thanks.
Monday, June 30th, 2008 AT 4:04 PM
The D4 light is it On and CEL? -P1768 pertains to the linear solenoid-
Monday, June 30th, 2008 AT 8:50 PM
KHLOW2008
  • 41,814 POSTS
Hi drowser,
Is the Check engine light showing?
If the trans is not fully electronically controlled, ie. It has a trans throttle pressure cable(1996 models most are without TCM), then the OBD II scanner reading is non comprehensive and would not have a linear solenoid.
Only one problem can cause the code, faulty or disconnected lock-up solenoid.
Tuesday, July 1st, 2008 AT 10:44 AM
