1996 Honda Civic transmission
MOMMACITASWEETS
Engine Mechanical problem
1996 Honda Civic 4 cyl Automatic
My honda civic radiator was bad so i replaced it. The transmission line then started to leak. The line was loose so i tightened it. Then I started to drive the car and transmission fluid comes flying out all over. I continued to tighten the line but it still leaks out of control. I am losing fluid fast. What could the problem be?
Jul 21, 2009 at 2:27 PM
  • 31,937 POSTS
Hi there,
I would say the the union is damaged In some way or there is a crack in the oil line, undo it and clean it up have a very close look you should be able to see something amiss.
mark (mhpautos)
Jul 21, 2009 at 3:20 PM
