1996 Honda Civic Shifts hard out of park
114,675 MILES • 4 CYL • FWD • AUTOMATIC
TCHOURB1
Hello, I have an issue with my car. It shifts hard in and out of Park but all the other gears are smooth shifting..I was wondering if I could get some input?
Mar 17, 2009 at 6:06 PM
F4I_GUY
  • 3,302 POSTS
Very, very, very common issue.
The shifter linkage pivot near the transmission needs to be lubed up.
Follow the shifter linkage underneath the vehicle, you will see a little bracket covering it up where it goes into the transmission. I believe it's 4 12 mm bolts. Remove the cap/cover and you will see the pivot and the cable. Get some penetrating fluid and soak it while shifting back and forth (either have a friend inside the vehicle or you can do it by hand by pulling the cable). Eventually you will feel it start to loosen up.
Goodluck.
Mar 18, 2009 at 12:28 PM
TCHOURB1
Thanks !
Mar 18, 2009 at 1:06 PM
