Hi jamal2000,
Slipping during gear changes means the line pressure is low. Check the trans throttle cable, if it has too much slack, readjust it.
The other cause is a weak clutch, you need to rebulid the trans.
SPONSORED LINKS
Monday, June 23rd, 2008 AT 9:57 AM
