1996 Honda Civic Replacing Axels
115,000 MILES • 4 CYL • 2WD • AUTOMATIC
F0RUMRID3R
Both my front axels are shot on my car. Just wanted to know if this is something that i can easily just do myself or should i pay for it to be professional repaired. Im pretty mechanical and fix alot my car issue's. Thank you for your help!
Apr 2, 2009 at 4:20 AM
F4I_GUY
  • 3,302 POSTS
It is not a difficult job, however if rust is an issue on your vehicle, getting the axle nut loose might be difficult.
Also, you'll need a few 'speciality' tools. A pickle fork to seperate the balljoint from the lower control arm. And a 32mm socket for the axle nut.
If you have access to these tools then go for it! You may want to soak the axle nut in penetrating fluid a day before you do this job though. Giving it a day to soak up will really help you out when you go to remove it.
Apr 2, 2009 at 11:25 AM
