1996 Honda Civic Power Windows
BEN HORNE
Electrical problem
1996 Honda Civic 6 cyl Front Wheel Drive Manual
How do I get the driver side interior door panel off so I can check the wires to the power windows?
Feb 2, 2009 at 7:00 AM
KHLOW2008
  • 41,812 POSTS
Hi Ben,
Lower door glass to lowest point.
Remove the inner door opener by removing the attaching screw and pushing it forward. Disconnect the opener linkage.
Remove screws of panel, on handle area.
If side mirror inner cover is obstructing panle movement, pry it off.
The panel is clipped on, pry off clips around panel with a padded screwdriver.
Lift panel up to get clear of the door upper sill.
Disconnect all wire sockets.
Feb 6, 2009 at 2:35 AM
