1996 Honda Civic piston ring clearance
1996 HONDA CIVIC
300,000 MILES • 4 CYL • FWD • MANUAL
AXIS
  • 107 POSTS
a friend replaced the engine of his 1999 civic after blowing his old engine.instead of throwing away, i offered to buy it for a very small amount thinking i could get some undamaged and useful parts. i disassembled the engine and found the only obvious damage was the no.3 crankshaft bearing and the shaft. the rest looks ok except a little grinding of the valves and seats. im not sure about the piston rings if its a good idea to use it on my car when its my time to make an overhaul.I was told the old engine was doing 125mph when it blew,so i guess compression was still good, i need some advice and info about the clearance of piston rings. .tnx.
Aug 6, 2010 at 3:32 PM
Rings
End Gap
Top Ring
Standard0.006-0.012 (0.15-0.30)
Service Limit0.024 (0.61)
Second Ring
Standard0.012-0.018 (0.30-0.45)
Service Limit0.028 (0.71)
Oil Ring
Standard0.008-0.028 (0.20-0.71)
Service Limit0.031 (0.79)
Ring-To-Groove Clearance
Top Ring
Standard0.0014-0.0024 (0.035-0.061)
Service Limit0.0051 (0.130)
Second Ring
Standard0.0012-0.0022 (0.030-0.056)
(1)Measure piston diameter 0.20" (5 mm) from bottom of piston skirt.
Aug 6, 2010 at 4:53 PM
