1996 Honda Civic my car won't move
202,100 MILES • 4 CYL • FWD • MANUAL
HONDAFAN24/7
i don't know if it is the clutch or driveline or both, but it will drive thru to 3rd gear then it will quit, but the transmission still turns, and clutch will allow me to go thru the gears but no movement??? If I let it set for a little bit then it will repeat the same thing.
Aug 25, 2010 at 5:01 AM
KHLOW2008
  • 41,812 POSTS
Hi HondaFan24/7,
Symptoms indicates it could be a clutch fault.
Is the clutch pedal stiff when problem occurs?
Aug 26, 2010 at 7:33 AM
AXIS
  • 107 POSTS
do you feel any slipping in your clutch on first and second gear,its probably a worn out clutch lining.
Aug 26, 2010 at 12:19 PM
