1996 Honda Civic my car smokes
198,776 MILES • 4 CYL • FWD • MANUAL
TAJASBABA
well i did the compression test, and the fact is that the results came out to be the valves or the valve seals. Should i just take the head off and do all the valves and seals, or should i just do the ones that are bad. now when i do this i have to to a timingbelt and water pump. Right?
May 31, 2009 at 11:22 AM
F4I_GUY
  • 3,302 POSTS
No you cannot put a 1.7 in your civic. Put the 1.6L back in.
Do a compression test to see what is really going on.
May 31, 2009 at 2:16 PM
RYBREAD68
If u change to the 1.7 u will probably have to change the ecu, so if u have that then u might as well rebuild that 1 b4 u put it in and that way u are putting in a brand new engine and your car shouldn't be off the road for more than a day. Then u can decide what to do with the 1.6, sell/rebuild/performance? If not then I would do what the other guy said.
Jun 2, 2009 at 2:42 PM
