1996 Honda Civic engine knocking
148,885 MILES • 4 CYL • FWD • MANUAL
CORYAR
my check engine light came on so I ran the diagnostics on it and it said knock sensor bank 1 p0328. the guys at shucks said the sensor could be going out is there a cheaper solution to try first.
Aug 11, 2008 at 12:45 PM
  • 31,937 POSTS
Hi there,
If the knock sensor has failed the ECU will not adjust the ignition timing when it starts to ping, this will cause poor performance, poor fuel economy and you run the chance of burning a hole in a piston from the detonation, get it fixed properly.
Mark (mhpautos)
Aug 11, 2008 at 12:59 PM
