1996 Honda Civic Electrical Door Window
90,000 MILES • 4 CYL • 4WD • AUTOMATIC
ITSMEVATO
How to replace electrical window assembly
Jan 12, 2009 at 6:50 AM
KHLOW2008
  • 41,812 POSTS
Hi Itsmevato, Remove the door panel and lower the door glass till the door glass mount bolts are aligned with the service hole. Remove the bolts. Disconnect the motor wire connector. Remove the regulator and motor ( not shown) mounting bolts. Regulator and motor assy can now be removed.
https://images.2carpros.com/forum/automotive_pictures/192750_Civic99DoorRegulator01_1.jpg
Jan 14, 2009 at 2:19 AM
