1996 Honda Civic electrical
1996 HONDA CIVIC
143,000 MILES • 4 CYL • FWD • AUTOMATIC
CURTIS CERVANTEZ
what could be the problem if my passenger side windows dont work not even from the master switch, and will that have an effect on my mirror switch couse the passenger side mirror dont work either
Jul 3, 2009 at 4:58 AM
F4I_GUY
  • CAR REPAIR CONTRIBUTOR
  • 3,302 POSTS
Pull the door panel off and look for any pinched wires. You may also want to look at where the harness enters the door. This is a common place where wires get cut and short.
If you cant find anything, check to see if the window motor is getting power and ground when you activate the switch.
Jul 3, 2009 at 6:09 PM
