1996 Honda Civic distributor
130,000 MILES • 4 CYL • FWD • AUTOMATIC
BINZ21
i put in a new distributor coil,new ignition wires and spark plugs, everything is new from the dealership. when i drive for certain amount of time my car stalled and died out.when i step on the gas im not getting alot of power and thats when it stalled. Before everything was working good until i changed the coil because it was burnt out. driving is different now im not gettin the same power when i step on the gas peddle like before. HELP ME PLEASE!
Jun 30, 2008 at 10:58 PM
KHLOW2008
  • 41,812 POSTS
Hi binz21,
Are the wires at ignition coil securely attached?
Did you check the ignition timing after changing the coil?
Were the plug cables installed securely and correctly?
Jul 1, 2008 at 3:58 AM
