1996 Honda Civic Cylinder #3 backfiring
1996 HONDA CIVIC
STEVEAL01
  • 140 POSTS
1996 Honda Civic 130000 miles
My buddys civic had the engine light on. His Mechanic scanned the system and states that the valve on #3 wont close which is causing a backfire on #3 only. Car is in descent shape except for this problem. Is there a way to clean that carbon build up by additives with out pulling the entire head?
By the way , that mechanic actually told him to drive it to the ground and even unplug the #3 injector to lean out the fuel using?????
Jul 9, 2010 at 12:36 AM
DOCFIXIT
  • 18,828 POSTS
First I'd check vakve adjustment then run SeaFoam through to decarbon
Jul 9, 2010 at 7:49 AM
