1996 Honda Civic condensor and coolong fan problem
1996 HONDA CIVIC
114,000 MILES • 4 CYL • 2WD • AUTOMATIC
IZALLDAT
hi, i have a problem with my ac, the condensor fuse keeps blowing. when i first start the car with a new fuse, it works fine. then after like 5-10 min after the car is warmed up, the cooling fan turns on and pops the condensor fuse but the cooling fan is ok. i have replaced both relays and i have checked if the fans lock up or not and they are both fine. they spin easily with no problem.
Apr 26, 2009 at 7:26 AM
F4I_GUY
  • 3,302 POSTS
https://images.2carpros.com/forum/automotive_pictures/276698_ac_fuses_1.jpg
Hi, can you please tell me which fuse it is?
Apr 26, 2009 at 11:31 AM
IZALLDAT
um its the 20 amp condensor fan fuse only ,the cooling fan fuse is also a 20 but it never blows , thnx 4 the quick reply
Apr 26, 2009 at 2:16 PM
ATKAPARKING
  • 64 POSTS
For a quick and dirty troubleshooting method, try disconnecting each fan in turn and seeing if the fuse still blows.
Apr 30, 2009 at 5:19 AM
