HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Civic
Engine
Symptoms
Revs Up
SPONSORED LINKS
1996 Honda Civic Car jerk at 1500 RPM
ZEE1522
MEMBER
1996 HONDA CIVIC
4 CYL
2WD
MANUAL
115,000 MILES
Hi my car jerk at 1500 rpm and the engine light is contantly on. Any suggestions.
Thanks
Monday, November 24th, 2008 AT 11:18 AM
KHLOW2008
MECHANIC
Hi zee1522,
Get a scan done to find out what is causing the Check Engine light to show.
SPONSORED LINKS
Monday, November 24th, 2008 AT 3:40 PM
ZEE1522
MEMBER
I think its a EGR. I went through lot of website and they mention EGR what you think. Thanks
Tuesday, November 25th, 2008 AT 6:39 AM
KHLOW2008
MECHANIC
Hi zee1522,
There are a 1001 thngs that I can think of, which would you like me to tell you?
Get a scan done and come back with the code so that we understand what is happening.
Tuesday, November 25th, 2008 AT 7:04 AM
Please
login
or
register
to post a reply.
Related Engine Revs Up Content
1996 Honda Civic 1996 Honda Civic Automatic Rpm Falls...
Reggie Here From Philippines Too, Have Same Problem With My Honda, Rpm Falls To 200-300 Rpm When You Release The Accelerator, This Is...
Asked by
blackhonda2009
1996
HONDA CIVIC
GUIDE
Idle Air Control Motor Replacement
The idle air control motor or idle speed control motor is designed to adjust the air flow into the intake manifold at engine idle. Engine idle speed is monitored by the PCM...
1996 Honda Civic Maximum Engine Rpm
My Engine Seems To Loose Fuel Supply When I Reach 55 Kph On First Gear. The Engine Seems To Have More To Give But There Seems To Be A Limit...
Asked by
axis
1 ANSWER
1996
HONDA CIVIC
1996 Honda Civic Rpm Fluctuates During Idle
Hi Guys, Here's My Problem. I Have A '96 Honda Civic That Recently Overheated. I Had That Fixed (replaced A Leaky Pipe). At The Same...
Asked by
kimd2057
1 ANSWER
1996
HONDA CIVIC
1996 Honda Civic When Idoling Car Reves Up And Down
My Mechcanic Said That Either The O2 Sensor Or Map Sensor Need Replaced. What Do You Think? Do You Know Any Resources For Finding Used...
Asked by
katilemmo
1996
HONDA CIVIC
1996 Honda Civic Car Wont Go Past 3 Rpm
Engine Performance Problem 1996 Honda Civic Front Wheel Drive Manual Have A 96 Honda Civic Starts Up An Idals Just Fine But When U...
Asked by
hondaek2
1996
HONDA CIVIC
VIEW MORE
SPONSORED LINKS
Vacuum Leak
Vacuum Leak Symptoms
Online car repair manuals
