Reggie here from philippines too, have same problem with my honda, rpm falls to 200-300 rpm when you release the accelerator, this is when the aircon is on. At times it is ok but when the rpm falls, you can feel that the engine is vibrating somewhat as if going to a stop, but then the rpm up and falls again. Normally the rpm needle stays on it's original 800-900 rpm during idle or whenever I release the accelerator. Please help. The mechanic adjustic something loosening the 2 screws and lifting the device a little up ( I don't know if it's the IACV ), for a few hours the rpm is ok but then problem re-occurs. What could the problem be?
SPONSORED LINKS
Tuesday, May 19th, 2009 AT 12:51 AM
