1996 Honda Civic air conditioner wont run
121,000 MILES • 4 CYL • FWD • MANUAL
RACHAEL21
I hae a 96 honda civic and there is plenty of free-on in the system but the compressor isnt kicking on. weve tested everything and the clutch doesnt seem to be getting anything from the inside of the car to tell it to kick on. theres continuity through the wires to the clutch. but nothing at the relay switch itself.
Sep 7, 2009 at 9:01 AM
KHLOW2008
  • 41,812 POSTS
Hi Rachael21,
Does the condenser fan comes on when the AC is activated?
Does bypassing the clutch relay activate the compressor clutch?
SYMPTOM TESTS
COMPRESSOR CLUTCH INOPERATIVE (CONDENSER FAN OKAY)
NOTE: This procedure assumes refrigerant pressure is okay (A/C pressure switch is closed).
Check fuse No. 17 (7.5 amp) located in under-dash fuse/relay box and fuse No. 56 (20 - amp) located in under-hood fuse/relay box. Replace fuses if defective and retest. If fuses are okay, remove and test compressor clutch relay. Replace compressor clutch relay if defective and retest. If relay is okay, turn ignition off and remove compressor clutch relay from fuse/relay box. Using a DVOM, measure voltage between compressor clutch relay cavity No. 2 of
under-hood fuse/relay box and good chassis ground point.
COMPRESSOR CLUTCH & CONDENSER FAN INOPERATIVE
Let me know which of the above 2 conditions are true and I will provide additional testing procedures.
Sep 8, 2009 at 2:10 AM
