Hi there,
The large nut with a split pin is the drive shaft lock nut, do not undo this, Just undo the wheel nuts and the wheel will come off, if it is sight, as some mag wheels can get, you will have to use a bit more force, just leave a wheel nut on loose so it wont come of and hurt you if you need to get physical with it.
Mark (mhpautos)
SPONSORED LINKS
Wednesday, May 14th, 2008 AT 9:26 PM
