1996 Honda Civic
LUIGI1
  • 1996 HONDA CIVIC
  • 4 CYL
  • 160,000 MILES
I have to jump start the car when ever I want to turn the car on.I jump started the car and turned the car on and once the car was on, the car started accelerating by itself and wouldn't let me put it on drive or any gear.
Tuesday, July 8th, 2008 AT 10:04 PM
KHLOW2008
  • 41,814 POSTS
Hi luigi1,
Is the battery bad? Why need to jump start each time?
When the engine starts cold, the fast idle is operating so the rpm would be high, it should go down when it warms up. If it does not, you should check for vacumn leakages, low coolant level and the idling system.
If the shift is locked in park and cannot shift out, check if the brakes lights are working. If not, the fuse or switch is faulty causing the interlock not to function.
Wednesday, July 9th, 2008 AT 2:27 AM
