1995 Honda Civic white smoke out of exhaust.
291,000 MILES • 4 CYL • FWD • AUTOMATIC
SHATTAZ8
my civic has been running pretty good up untill now. i was driving and it slowly cut off with a little struggle while i was moving with a whole lot of white smoke out of the muffler. whats the problem?
Nov 22, 2008 at 8:17 AM
DAVE H
  • 13,383 POSTS
have your cylinders compression tested .. i think your head gasket has blown ??
Nov 22, 2008 at 9:13 AM
F4I_GUY
  • 3,302 POSTS
Headgaskets were semi-common on higher mileage obd1 honda engines.
A quick home test would be to open your rad cap, if the coolant is over-flowing/bubbling or you see exhaust smoke, you have a major problem. however, the only real way of knowing is to have a leakdown test/compression test done.
Nov 24, 2008 at 12:20 PM
