Hi avcmksh,
Thank you for the donation.
Symptom indicates apowe rsupply failure.
Check the underhood main fuses. Another possible cause would be the ignition switch. Note if the dash lights are showing when ignition is turned on and while cranking. If the dash lights goes off or flickers when the ignition is turned to START, the ignition switch is suspect.
SPONSORED LINKS
Friday, October 1st, 2010 AT 8:36 AM
