1995 Honda Civic engine dies will driving during hot condit
THETECHNICIAN
  • 1995 HONDA CIVIC
  • 4 CYL
  • MANUAL
  • 185,000 MILES
I had my distributor changed about 3 months ago (3k miles), plus timing belt and tuned up. While driving the engine just shuts off. I wait a few minutes and then it runs fine for about 5 minutes then shuts off like the key was turned off. I do get a check engine lite but turns over no problem. Its really bad when its really hot 90 plus. Any suggestions?
Thursday, August 7th, 2008 AT 7:45 AM
KHLOW2008
  • 41,814 POSTS
Hi thetechnician,
You need a scan to find out what is indicated by the CEL.
As to the engine stalling, I would suggest checking the main relay. If CEL does not go off when ignition switch is turned on and difficult to start, the ECM might be faulty.
Sunday, August 10th, 2008 AT 8:13 AM
