1995 Honda Civic vales settings
BRONKIES
Engine Mechanical problem
1995 Honda Civic 4 cyl Two Wheel Drive Manual
Good day, I need some info on settings for above car. Vlave clearance exh. and inlet. and must the settings be done cold or hot? best regards. Robert.
Feb 4, 2010 at 8:05 PM
HONDA TECH 1818
  • 536 POSTS
Intake: 0.18—0.22 mm (0.007—0.009 in)
Exhaust: 0.23—0.27 mm (0.009—0.011 in)
If you must adjust the clearance on a
warm engine at a routine maintenance interval, use a
fan to cool the engine until it’s barely warm to the touch[100 degrees F (38 degrees C)] . With the cylinder head at this temperature, adjust the valve clearance to the maximum specification.
Feb 7, 2010 at 5:31 PM
