When changing my spark plugs oil was on the spark plug. Why? And what could be the problem? And how do I fix it
Friday, October 24th, 2008 AT 8:49 PM
KHLOW2008
MECHANIC
Hi valeriecoronalopez73,
There are 2 places that can cause engine oil leakages into the plug holes.
1. Valve cover plug seals. You can replace by removing the valve cover.
2. Cam carrier O ring seal. You need to remove the cam carrier to replace. This would normally have more oil in cylinder #3 as there is a pressure passage within the O ring seals.
