1995 Honda Civic shift problem
120,000 MILES • 4 CYL • FWD • AUTOMATIC
SANDJAUTOMOTIVE
Transmission works fine at start up and then after 1-2 miles or so disengages/slips in all gears forward and reverse. Turn the ignition off, restart and it works fine again for a distance.
Jul 12, 2009 at 5:35 PM
KHLOW2008
  • 41,812 POSTS
Hi SandJautomotive,
Thank you for the donation.
If the trans fluid level is correct then the fluid filter, which is a non serviceable part located in the trans assy, is clogged and you would have to rebuild or replace the trans.
Jul 13, 2009 at 3:55 AM
