Hi, I got a problem with my rear brake on the left tire. The brake stays in friction even noe that I have released the emergency brakes. In summer i changed the the brake caliper, the rotor and the brake pads of my rear left tire. Last two weeks i noticed that when i was driving i couldn't go faster because something was stoping me from the back, i pulled over and i smelled burning from the left tire, i took a look at it and the disk was so hot and looked red like a pizza grill, this was because the pads weren't loose at all and were forcing the disk to stop. I thought that the brake cable might be frozen and can not release the pads from putting pressure on the disk, so i had to replace that. I did replace the brake cable the car worked fine only for 4 days and it did it again today, and i don't know what is causing it? Can it be the corkscrew device not functioning well? Can somebody help me with any suggestions? Thank you
Dec 27, 2009 at 1:55 PM
