1995 Honda Civic Rattle from the fuel filter?
164,000 MILES • 4 CYL • 2WD • MANUAL
MRCRAIGAR
I just bought this car not too long ago with no motor. I replaced the motor with a JDM engine and the car runs and drive great (although I checked the oil level today after about 800 miles of driving and it seems to be down ½ quart). My question is while sitting in the car at an idle there is a very noticeable rattle or clicking that almost sounds like a valve train noise. After listing to every surface of the engine and engine compartment if seems like the noise is coming from the fuel filter which is attached to the firewall and would make sense as to why its audible from inside the car. As soon as you start to move the car the noise goes away. I have also unbolted the fuel filter from the firewall and the noise goes away. Today I replaced the fuel filter again and no change. Any ideas?
Nov 2, 2009 at 11:02 AM
  • 110,244 POSTS
It has to be one of two things. Either the rubber mount on the firewall (where the filter mounts) is missing or bad or the fuel pressure regulator is allowing too much pressure to build. Have you checked the fuel pressure?
Nov 2, 2009 at 12:02 PM
MRCRAIGAR
[quote:86336e406b="Jacobandnickolas"]It has to be one of two things. Either the rubber mount on the firewall (where the filter mounts) is missing or bad or the fuel pressure regulator is allowing too much pressure to build. Have you checked the fuel pressure?[/quote:86336e406b]
I will check the pressure tomorrow.
I don’t remember any rubber mounts on the clamp that holds the filter or the mount on the firewall. I’ll see if I can find an exploded view of the mount assembly that might show me if something is missing.
Any ideas what the oil consumption might be? No smoke or leaks. Could it be temporary because the motor sat for awhile?
Nov 2, 2009 at 5:22 PM
  • 110,244 POSTS
Actually, it may be considered normal. For example, Chrysler considers a quart in 1000 miles normal. I would wait to see if any leaks show up.
Nov 2, 2009 at 11:50 PM
