1995 Honda Civic Press Brake pedal and front side lights co
90,000 MILES • 4 CYL • FWD • AUTOMATIC
K24CIVIC
Hi, when my cars lights are turned OFF, and i press my brakes the front lights (side lights) come on too..
And the stereo and the clock and dails all go dim until i release the brake pedal
When i turn ON my front lights all the interior lights go dim and everything is fine
its only when the front lights are turned OFF , that when i press my brakes its seemed like its acting like a dimmer
And with the keys out of car and depressing brake pedal it makes the Beep sound, which i normally get when i leave the lights on ...But lights are OFF and brake depressed it BEEPS
only thing i have done since its add a bass box and amp...i am thinking it could be something to do with the remote wire..Not sure
Any help please?
thanks
Jun 16, 2008 at 7:50 PM
BMRFIXIT
  • 19,053 POSTS
recheck the wiring
you must have crossed some wire some where
and would also check light bulbs in the back
maybe a wrong bulb was installed causing a feed back
Jun 16, 2008 at 11:42 PM
KHLOW2008
  • 41,812 POSTS
Hi k24civic,
Don't forget to check for badly connected ground, especially at rear taillights.
Jun 17, 2008 at 3:04 AM
K24CIVIC
thanks loads for your tips
i will give them a try tommorow...hopefully something will work out
kind regards
Jun 17, 2008 at 12:24 PM
K24CIVIC
thanks for your help guys was the brake light bulb, i fitted the wrong type ...DUH...all okay now
thanks again
Jun 17, 2008 at 11:21 PM
