1995 Honda Civic overheating
BO TAVAKOL
  • 1995 HONDA CIVIC
  • 4 CYL
  • FWD
  • MANUAL
  • 16,400 MILES
My Honda Civic was running fine until last night when it began to overheat. I have noticed leakage below the radiator, the cooling fan does not turn on (at least I have not seen it do so), and the engine also "heaves" with the tacometer going up and down (between 0-2) while the engine is idling. Do you think this is a head-gasket problem or a fan switch problem or something else? Thanks much!
Monday, March 1st, 2010 AT 7:07 PM
BLUELIGHTNIN6
  • 16,542 POSTS
If radiator fan isn't coming on then you need to check fuse and cooling fan relay. Also need to inspect the engine oil and coolant levels and see if either seem milky / mixed. Is the engine light coming on?
Monday, March 1st, 2010 AT 7:31 PM
BO TAVAKOL
No, the engine warning light hasn't come on, and neither the oil nor the coolant seem milky. I thought that a hose might be leaking, but it's the up/down heaving of the engine I'm most concerned about (in addition to the overheating). Thanks!
Monday, March 1st, 2010 AT 9:03 PM
BLUELIGHTNIN6
  • 16,542 POSTS
The idle issue is pretty common in these hondas and is normally caused by the idle air control valve failing.
Tuesday, March 2nd, 2010 AT 10:12 AM
