1995 Honda Civic No hot Air
SUPJASMINE
Air Conditioning problem
1995 Honda Civic 4 cyl Automatic 122000 miles
I bought my 1995 Honda Civic last year and the hot air worked fine on it. I only used it for the last month of the winter month. This year starting in November my hot air was fine for the first 2 weeks and all of a sudden it quits heating up. It blows out air like normal its just not hot air. We have had 22 degree weather here and it has been a real problem since the heat does not work. We had the radiator replaced because I was told it was the radiator. I was told that it could be the hot air blower motor. What do you think?
Feb 5, 2009 at 5:20 AM
2CARPRO JACK
  • 11,533 POSTS
Does it blow air out of the vents? if so the blower motor is probably ok.There is a cable that hooks to the heater control valve. The valve is inline on the heater hose under the hood.Have someone work the temp selector in the car and watch to see if the cable moves. If not it may have a broken cable or the lever that controls it
Feb 5, 2009 at 12:36 PM
