I will try to answer your questions as best as I can.
There is nothing on a car called a "water heater" or an "oil gasket" so i'm do not know what items have been replaced.
Probably because it has an oil leak.
There are around 10 places on most engines that can leak oil. I can not tell by the information you have given me, what has been replace. Or if it was replaced correctly.
Because it's still is leaking somewhere, or wasn't filled up after it was worked on.
Tuesday, July 7th, 2009 AT 12:46 AM
