1995 Honda Civic MAP sensor reading
205,100 MILES • 4 CYL • FWD • AUTOMATIC
XTINA22
OK. I have a 95 civic EX 1.6 liter. My engine light is on so I purchased an OBD1 code reader. I tested it and test indicated MAP sensor. I tested the sensor, its good. What are other likely problems my car may have? The issues my car seems to have include; significant reduction in mileage(from 30mpg to 22mpg highway), overheats sometimes(only in idle position), coolant disappears but goes nowhere(not leaking and not in oil, it just evaporates), a lag in acceleration. Please help. Thank you
Apr 17, 2010 at 11:44 AM
F4I_GUY
  • 3,302 POSTS
If you got a code for the MAP sensor, 9 times out of ten, the MAP is faulty.
Test to ensure there's a 5V reference and ECM ground on the harness connector. If there is, replace the sensor.
Apr 19, 2010 at 11:35 PM
