1995 Honda Civic Knocking/Thumping while brakeing
140,000 MILES • 4 CYL • FWD • MANUAL
ULTIMA.MANIAC
I just had my brake pads, brake lines, and master cylinder replaced by a mechanic after my brakes had failed on me. They work fine but now there is this loud knocking noise that occurs when I brake softly under 25mph. If I brake hard the noise goes away or if I brake over 25mph it doesn't make the knocking noise. The noise gets louder but slower as I get closer to stopping and seems to be coming from the front right wheel. Need some suggestions please, the noise is really audible and rather embarrassing when I have passengers.
Jun 9, 2008 at 6:56 PM
KHLOW2008
  • 41,812 POSTS
Hi Ultima.Maniac,
Most probably the rotor has a small bump or uneveness at the edges.
Hope is not the tires not properly torqued. Check for loose driveshaft nut or wheel bearing free play.
Jun 10, 2008 at 5:03 AM
