1995 Honda Civic idk what the problems is
1995 HONDA CIVIC
DMOODY1988
Electrical problem
1995 Honda Civic 4 cyl Front Wheel Drive Manual
i have a 95 honda civic non vtech 1.5 d15b7 manual i was driving downt hte road a month and a half ago and all the sudden it just died right after i shifted into second leaving the intersection i checked it and had a mechanic check it out i found and so did he that i was not getting spark i have replace the coil ,igniter, rotor, cap, tdc\camshaft postioning\crank postioning sensors fuel pump main relay and ecu and it still wont start i am getting spark now no gas or not enough some times it sputters but wont start. when i put the key in i hear the fuel pump run for like 3 seconds i hear the two clicks from the main relay but to no avail
May 23, 2010 at 11:52 AM
Check the fuel pressure if its within specs and also if the injectors are pulsing.
May 23, 2010 at 11:59 AM
