1995 Honda Civic idiot lights
155,000 MILES • 4 CYL • FWD • MANUAL
JABREPA
  • 9 POSTS
Hi. I have another problem that I just noticed with the civic I just bought. When i turn on the key and the idiot lights come on the "oil" light doesn't come on. Is it just a bulb or could something else cause it?
Mar 14, 2008 at 4:53 PM
PEAR69
  • 1,482 POSTS
With the engine NOT running and the key ON, the oil light should be on. If not then check the bulb and replace it if necessary. This light is, without a dought, the most important warning light on your car!! Be aware--this is a common trick to hide an oil pressure problem.
Mar 14, 2008 at 7:41 PM
JABREPA
  • 9 POSTS
Plug on oil sending unit had come off. You would think that would make the light stay on but it didn't.
Mar 15, 2008 at 8:14 AM
PEAR69
  • 1,482 POSTS
The light should be on if the sending unit is unplugged. The light must be burned out.
Mar 16, 2008 at 11:14 AM
JABREPA
  • 9 POSTS
That's what we thought too but light comes on when the ignition switch is turned to on and goes out when car starts. So I guess all is well?
Mar 16, 2008 at 6:41 PM
