1995 Honda Civic iacv valve
ESTAN49
  • 5 POSTS
Engine Performance problem
1995 Honda Civic 4 cyl Two Wheel Drive Manual
I have a honda civic 1995. Is there a way of testing the iacv valve to make sure its operating correctly? I was told that this can make the rpm needle to bounce up and down.
May 5, 2009 at 2:52 PM
F4I_GUY
  • 3,302 POSTS
You can unplug it to see if the surging is still there or not. The motor might stall out on your though (which is a good sign) so you should ease the throttle to an idle when you unplug it.
Usually though, its a combination of the FITV and IACV valves acting up. Remove both of them and clean them all up.
May 6, 2009 at 11:35 AM
