So i just replaced my cluch in my 1995 honda civic ex. and when i got it all back together and started to take it for a test drive i realised that the speedometer was not working so i took a look at all of the wiring just to make sure every thing was pluged back in correctly and it was then i checked to see if there was a fuse that had blowen when i pluged back in the battery after i had finish with the cluch but i could not find one that said anything about the speedometer or odometer so i though well maybe i had broken the spline to the speed sensor ( i think it is called ) so i checked that but it is still moving just fine so i though it was the sending unit itself but i replaced it and still nothing so i am bafold as to what it is..... what i would like to know is there a fuse i am not seeing or am i going to have to rewire the harness that goes to the speed sensor ?
edit: i forgot to tell everyone that my check engine light is coming on after about 10 mins of driving as well now so i am really scratching my head ....and i did read the other post on speedometer but i had already done that in my case
Sep 30, 2008 at 4:39 PM
