1995 Honda Civic Heath
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
ERDOS
The car is more heath than normal when is running. sorry i dont speak english.
El carro esta mas caliente de lo normal cuando esta andando en una loma
Aug 26, 2009 at 11:54 AM
KHLOW2008
  • 41,812 POSTS
Hi erdos,
From the Spanish translation, you mean the temperature gauge goes up when going uphill?
If that is the case, the most likely problem would be a partially clogged radiator. Check if the coolant level in radiator is correct.
Aug 31, 2009 at 8:52 AM
