1995 Honda Civic erractic idle/runs rich
DIESEL718
Engine Performance problem
1995 Honda Civic 4 cyl Front Wheel Drive Manual
my civic runs good but a little rich at start up but when it warms up, the idle goes up and down and when i stop sometimes it sounds like it wants to shut off.at the same time its running extremely rich. could the IAC be the problem or maybe timing?
Jul 27, 2009 at 12:09 PM
  • 75,988 POSTS
Could be the IAC and the following below
Possible causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
Jul 27, 2009 at 1:18 PM
