1995 Honda Civic Dx Coupe
TXIKI
  • 5 POSTS
Hi:
112000miles,l have to replace the head gasket( small leak) How difficult is to do it? Also should I do something else besides the gasket? If is difficult how much can be if the job is done with a mechanic? Thanks
Jan 13, 2007 at 12:50 AM
BRUCE HUNT
  • 3,754 POSTS
$500 to $800 by a mechanic. The parts you would need to do it yourself. Repair/Maintenance manual for about $20 from parts store. Then you need to take off the head and take it to a machine shop. For about $60 they will plane it and check for cracks and look at the valves.
I would replace the timing belt while in their as well as the water pump and check out the idle pulley/self tightner.
It is some work, pretty straight forward and rewarding to say you did it and a job well done!
Jan 13, 2007 at 9:00 AM
