1995 Honda Civic Coking
66,000 MILES • 4 CYL • FWD • MANUAL
CHRISSAGGESE
My alternater went so i replaced it myself. I started it up and changed how tight the belt was so it would screatch. Then when i started it back up it sounded like it was coking so then i looked at my engine and took of the intake and there was white smoking coming out of the intake. Seems like it was a little wet inside the intake manfoild. Dried it out and still was coking, no power to the engine or anything. Any Ideas??
Oct 5, 2009 at 8:53 AM
F4I_GUY
  • 3,302 POSTS
Perform a cylinder balance test and go from there.
If you have one or two dead cylinders check ignition to that cylinder, fuel injectors and compression
Oct 5, 2009 at 11:43 AM
