1995 Honda Civic Clutch
1995 HONDA CIVIC
88,000 MILES • 4 CYL • 2WD • MANUAL
SPINNER70
The clutch squeaks when I depress it until it is well warmed. It almost sounds like it should be oiled but my son said maybe there was a deeper problem. I am traveling on a 500 mile trip soon and don't want my clutch going out on a hill. Help!
Thanks.
As you can see the car is 15 years old but has relatively low mileage. I have replaced the clutch twice, I think but once about 8 years ago for sure.
Jun 29, 2010 at 9:14 AM
  • 31,937 POSTS
Is this noise there with the engine running only or will it do it with the engine off as well?
Mark (mhpautos)
Jun 29, 2010 at 9:46 AM
SPINNER70
The clutch squeaks whether the motor is on or off. Thanks for your help in figuring this out
Jun 29, 2010 at 11:47 AM
  • 31,937 POSTS
If this noise is from under the dash it will be the pedal pivot, a good spray with a lube should take care of this, if i is under the front of the car, it will be the clutch fork pivot, this will require the removal of the transmission to fix.
mark (mhpautos)
Jun 29, 2010 at 2:19 PM
