1995 Honda Civic Clutch
SEMPULLMAN69
Drive Train Axles Bearings problem
1995 Honda Civic 4 cyl Two Wheel Drive Manual
how to replace clutch slave? How to bleed lines?
Aug 2, 2008 at 4:36 PM
KHLOW2008
  • 41,812 POSTS
Hi sempullman69,
Disconnect the fluid hose, remove the holding bolts and take cylinder out.
Reinstall in reverse. Top up fluid in reservoir.
Get someone to pump clutch pedal and hold down. Release bleeder nut at slave and tighten. Repeat process till no more air comes out of bleeder hole.
Aug 7, 2008 at 12:47 AM
