Can't figure it out. Took car to 2 different shops.
1st shop, 3 bad tie rods I told them to do all 4 they said other one is fine replaced 3 and aligned.
Seemed to be ok for a couple of days.
2nd shop, bad tie rod, showed me the play in it had it replaced and realigned ok for around 2 days.
Balanced tires and rotated seemed better for around 2 days. Took back, was told left wheel bearing was bad, replaced, no difference, took back, they replaced both front tires rode great!!! for you guessed it around 2 days. I have spent almost a grand on this front end and it isn't any better.
Dash shakes and you can feel a vibration on your feet makes a growling or maybe you can call it a humming noise. When you go over rough roads noise is louder
and somtimes it feels like a tapping on the floor board
seems like its on the left side.
Replaced all tie rods, driver cv shaft and wheel bearing
both front struts, tires are new, rotors and pads maybe have 17k no pulsing brake pedal, no play in ball joints both shops check and so have I Please help I'm about tapped out!
Apr 7, 2009 at 1:56 PM
