1995 Honda Civic Car door handles
115,000 MILES • 4 CYL • FWD • AUTOMATIC
CBELT_3
The driver's INSIDE door handle broke apart as well as the right rear OUTSIDE door handle. I purchased used handles for the car but I am having difficulty figuring our how to get into the inside of the door. On the back door, I cannot figure out how to get the door panel off since the inside handle is attached. Same for the driver's front door....all the power window controls are attached and I don't know how to get into the inside of the door to replace the handles. HELP!
Aug 25, 2008 at 3:02 PM
KHLOW2008
  • 41,812 POSTS
Hi cbelt_3,
Thank you for the donation.
The driver door inner opener is secured by a screw and is clipped on. You need to push the assy towards front to get it off the locking tabs, unclasp the opener rod and remove it out.
Back Door opener removal is same as front.
Remove screws holdong panel and there are grommets that you need to unplug to get at some hidden screws.
The panel has to be pried off as it is clipped on with some attaching screws.
Aug 26, 2008 at 1:32 AM
