1995 Honda Civic Broken Dashboard Gauges
EKT
Electrical problem
1995 Honda Civic Automatic
All gauges on my car's dashboard have recently stopped working--the fuel, the speedometer, etc. In addition to this, the signal indicator for the left and right doesn't work either; however, the front lights as well as the taillights and brake lights work just fine. Also, the dashboard lights work. It doesn't seem to be a fuse problem because we've checked that and it didn't correct the problem. Could it be the cluster? The voltage limiter? What parts do we need to fix it and how much would it cost if taken to a local mechanic?
May 11, 2010 at 2:30 PM
F4I_GUY
  • 3,302 POSTS
Well first I would check to see if your cluster has power and ground. One might be missing, and you will have to go from there.
Personally I would double-check your fuses and make sure the connection at the back of the cluster is still good.
May 12, 2010 at 11:31 PM
