1995 Honda Civic Brake System
210,000 MILES • 4 CYL • FWD • MANUAL
KHAMXIONG
  • 7 POSTS
My brakes keep going down when i step on it. I have tired bleeding the brakes. it worked fine for a few minutes until the car got hot then the brakes started going down again passed normal. no leak in front brakes. master cylinder has no leaks, wires to the cylinder are good condition. tried bleeding them on both sides 7 times each. Need Help Asap.
Jun 17, 2008 at 7:50 AM
DOCFIXIT
  • 18,828 POSTS
Master cylinder must have internal leak past the piston seals. The master cylinder needs to be replaced
Hope this helps
Jun 17, 2008 at 8:10 AM
